Heater doesnt blow any heat out!!!!
Hi to all i have Trajet 2002 1.8 and the heater is not working does anyone have any ideas about a quick fix.
ITS GETTING COLD!!!!!!!!!!!!!!!!!!!!!!!!
OK, if the engine is operating at the normal temp, you might want to look at a blend door to verify it is working. if stuck in the position that allows too much cold air to blend with heated incoming air . A common problem and if you cannot verify that , have a shop check the blend door operation.
