hyundai trajet gsi td 2.0l 16v 2003
car will not start the car cut out on the motorway and now will not start got towed home and the recovery man said it seem like fuel problem put it in the garage who fitted a new fuel pump still the same turns over and trys to start then nothin just turns over it has now been in 3 garages who cannot find the fault the car was running fine untill this can anyone help or give me any clues ????? |
RE: hyundai trajet gsi td 2.0l 16v 2003
check the flow meter and good luck
ORIGINAL: accentgt check the flow meter and good luck car now back at home as nobody can find out whats wrong with it !!!! i need help |
try to get another flow meter from sombody u know that has the same car and put the other flow meter and start it and see if it starts.
Unable to startcld b due to several of issues.... stucked fuelline/injectors/faulty pump/spark plugs/manifold inlet valves/faulty ECU/sensors... etc. Don't waste $$ changing parts which is not revelant to problem.Unauthorised workshopsgains, u're d loser.
Sent it to an authorised Hyundai workshop for anOBD diagnostic check. It doesn't cost much in comparison to your 3x attempted wasted cost, right?? |
