trajet crdi timing belt replacement
ok,i have a 2002 trajet crdi and i need to change the timing belt.i normally change all my own belts but cant find any info on this model,has anyone there changed the same belt and did you meet any unexpected problems.its got a/con,just said this as it seems to bmp the labour charge up by £55 if a garage does it.they estimate 5 hrs labour=£255 +£138 for timing belt kit which is why i change my own.any advice/help wellcome,thanx,j.
If you could give us the engine model number, we might be able to help. I suspect it's like a Sonata or an Elantra motor here in the US.
Originally Posted by chenga
(Post 20735)
http://www.hyundai-autoclub.ru I know there is a pdf that includes timing belt replacement procedures. |
