Trajet engine blown...
Hi there i am new here....
i'm glad i found this site, because i have an big problem with my car. Few months ago an friend of mine, hit the oilpan( while driving bad road). and the engine broke down. Now the bigger problem is finding an eng. for this car so i was hoping that anyone here would know what engine fits in this car besides the original eng. this is Hyundai trajet 2002 2.0l doch with A/T one number under the eng is EF 2.0 if that would help.. Sincerly...Davíð örn... |
where are you located? that would help. RVK? not sure where that is.
Well it don´t matter longer since i found an eng for my car but to answer your question RVK means ReyKjaVík ,capital of Iceland....
engine replacement
Hi,
What engine did you use to replace the original Trajet engine? Trajetking |
Hi Trajet King, the answer to your question is that i found an ENG from an Sonata with EF 2.0 L 136HP MODEL 2000 if i remember correctly.
Trajet has the same ENG as Sonata from the year 98(99) to about 2002(04). And it can be found in some types of Coupe.. The best way to find out if it´s the same ENG is by matching 2gether top of the engine ( dont remember the name of this part. it´s where you pour the oile.) and by looking under the Block (infront of it) you should be able to see the marking there it´s EF 2.0...... I hope these information can be at any use for you or someone else.... Greetings from Iceland Davíð Örn Guðmundsson David Eagle Gods-man |
