-   Hyundai Tucson (https://www.hyundaiforum.com/forum/hyundai-tucson-24/)
-   -   05 Tucson 2.7 gls 02 sensor (https://www.hyundaiforum.com/forum/hyundai-tucson-24/05-tucson-2-7-gls-02-sensor-10316/)
clinton Feb 12, 2011 04:18 PM
I am looking for the bank 1 sensor 2 location on my Tucson. Also a "How to" on changing it out myself. Any diagrams, instructions and all help is greatly appreciated
NovaResource Feb 12, 2011 04:30 PM
This pic should help:
https://www.hyundaitechinfo.com/file.../03360121D.gif
Bank 1 is always the side of the engine with cylinder #1.
Bank 2 is always the side of the engine with cylinder #2.
Bank 1 is the bank of cylinders on the firewall side.
Bank 2 is the bank of cylinders on the radiator side.
Sensor 1 is the O2 sensor before the cat.
Sensor 2 is the O2 sensor after the cat.
So the one you want is the sensor AFTER the cat on the FIREWALL side of the engine.
clinton Feb 12, 2011 05:23 PM
You rock! Thank you sir! Would you happen to know how to replace it? This is new to me and I really want to learn how to do this myself on this Tucson.
NovaResource Feb 12, 2011 09:07 PM
This is sensor 2 in Bank 1 as seen from under the car:
https://www.hyundaitechinfo.com/data...G/egqe550o.gif
Basically unplug the connector and unbolt the sensor. Apply anti-seize to the threads of the new sensor without getting any on the sensor itself. Thread in and tighten (29.5 ~36.9 lb-ft). Plug in the connector. I'd advise getting a Hyundai sensor instead of a cheap off-brand one.
sbr711 Feb 13, 2011 02:44 PM
What is the code that lead you to think you need replacement ?
Couple of the codes are a program, nothing wrong with sensor, so you be throwing money away replacing sensor..
clinton Feb 15, 2011 04:05 PM
I had a mechanic from work hook up the code reader and thats what he said it was
clinton Feb 15, 2011 04:06 PM
http://www.hmaservice.com/data/Passe...G/egqe550o.gif
Thank you Nova!
sbr711 Feb 15, 2011 10:35 PM
Is your mechanic a Hyundai Tech ?
What is the P-xxxx code.. ??
So you is going to buy a sensor, and it may not be the real problem, when the repair might just be a PCM reprogram ??
I am trying to help you move the right direction..
clinton Feb 25, 2011 01:37 PM
I appreciate it man. he is not a hyundai tech and he didnt tell me the code. Now The hyundai stalled out on me at an intersection today
sbr711 Feb 25, 2011 06:40 PM
1 Attachment(s)
Easy repair... if the TPS has a grey body,,,,,, replace it with the newer black body TPS
Old TPS --
https://www.hyundaiforum.com/forum/a...1&d=1298680756
