2005 Hyundai Tucson - Replace Starter
REPLACEMENT
1. Disconnect the battery negative cable.
2. Disconnect the starter cable (A) from the B terminal (B) on the solenoid (C), then disconnect the connector (D) from the S terminal (E).
3. Remove the 2 bolts holding the starter, then remove the starter.
4. Installation is the reverse of removal.
5. Connect the battery positive cable and negative cable to the battery.
patrick2099
Feb 28, 2013 01:36 PM
GS Audio
Jan 5, 2009 01:41 PM
