-   Hyundai Tucson (https://www.hyundaiforum.com/forum/hyundai-tucson-24/)
-   -   2005 Hyundai Tucson - Replace Starter (https://www.hyundaiforum.com/forum/hyundai-tucson-24/2005-hyundai-tucson-replace-starter-13978/)
rwastudent7 Oct 16, 2013 11:43 PM
I may be looking to replace my starter in my 2005 Hyundai Tucson. Anyone have any instructions or diagrams I could use?
NovaResource Oct 17, 2013 10:27 AM
Which engine?
rwastudent7 Oct 17, 2013 09:53 PM
2.7l gls
NovaResource Oct 18, 2013 01:34 PM
REPLACEMENT
1. Disconnect the battery negative cable.
2. Disconnect the starter cable (A) from the B terminal (B) on the solenoid (C), then disconnect the connector (D) from the S terminal (E).
https://www.hyundaitechinfo.com/data...G/ebkd303a.gif
3. Remove the 2 bolts holding the starter, then remove the starter.
4. Installation is the reverse of removal.
5. Connect the battery positive cable and negative cable to the battery.
rwastudent7 Oct 30, 2013 12:37 AM
Thanks!
brutus2474Brutus Mar 27, 2018 10:58 PM
I can't get the heat shield out. Have it loose but can't get it out of the tight space. Any suggestions?
