2005 Tucson Tires, want bigger oner any suggestions
Hi,
I would like to get taller and wider tires on my 2005 tucson. right now it looks all wimpy with 215/65R15... Can anyone with knowledge of tires suggest what size i should go for. i dont need to go extreme it just doesnt look right. Thank You! |
You don't want taller tires because it will throw off the speedometer and odometer. Also, too tall will cause interference. If you want a slightly wider tire you can go with the tire size that is standard on V6 Tucsons: 235/60-16
what about...
I found some 265/60 -16 for a real good price. would those work? I know I sound stupid but Im just some gal who wants better looking tires. I never had to worry before, never had ones that looked so akward :cool:
The 265/60-16 tires is over 1.5" taller and 2" wider. Way to wide and too tall. And I highly doubt the tire woudl fit on the 6.5" wide factor wheel. It's just too wide.
Thank you Super Moderator! I'll keep looking...
235/65-16👌
they only rub a tiny bit when hard over either side '06 Tucson limited V6 4WD USA |
| All times are GMT -5. The time now is 08:29 AM. |
