2005 tucson wont blow hot air
Verify that the temp door is working properly. If ok then your heater core is clogged. To unclog, remove both heater core hoses that go to the thermostat housing and put a garden hose to the end to flush the heater core out. When you put hose on take note of what comes out of the other hose. Usually a thick snot like glob will come out. Also reverse flush the core as well
Should be on the passenger side (center) of vehicle below a/c control head. With vehicle running while looking under glove box turn the temp **** back and forth and see if the actuator moves back and forth. If it moves, heater core is likely clogged. Also while doing this you can hear the tone change (air movement).
ElantraOwners
Jan 24, 2011 08:07 PM
