2006 Gear knob removal
2006 Gear **** removal
Hi all. I bought my first Hyundai today. 2006 Tucson with some minor repairs to be done like replacing the gear ****. Only thing is, I can't get the thing off.
I can't find any info on this model specifically so I'm relying on someone here to guide me please. To me it looks like I should just be able to turn it counter clockwise but it will not budge.
Cheers
Cheers
You will have to be a little more detailed about this gear ****??
Is this a nut on the steering column?
Or a nut on the wheel axle?
What does the gear **** do?
And where is it located?
What year and model is it?
I am talking about the gear shifter on a 2006 tucson.
Cheers
Cheers
You didn't say if this was an automatic or manual but I'm going to assume automatic since a manual trans in the Tucson is a rarity.
It's very easy. At the base of the handle there is a small, oval cover with a tiny notch in the edge. Use a tiny flathead screwdriver to remove the cover. Under the cover is 2 Phillips screws. Remove the screws and the handle pulls up off the shaft.
This should help:
http://www.sound-repair.com/index.ph...-instructions/
I used to own a 2006 Tucson.
This should help:
Hyundai Tucson 05-07 Stereo Removal Instructions / Sound Repair
This should help:
