-   Hyundai Tucson (https://www.hyundaiforum.com/forum/hyundai-tucson-24/)
-   -   2006 Gear knob removal (https://www.hyundaiforum.com/forum/hyundai-tucson-24/2006-gear-knob-removal-16467/)
windkind May 21, 2017 01:32 PM
Hi all. I bought my first Hyundai today. 2006 Tucson with some minor repairs to be done like replacing the gear knob. Only thing is, I can't get the thing off.
I can't find any info on this model specifically so I'm relying on someone here to guide me please. To me it looks like I should just be able to turn it counter clockwise but it will not budge.
Cheers
avisitor May 21, 2017 10:29 PM
You will have to be a little more detailed about this gear knob??
Is this a nut on the steering column?
Or a nut on the wheel axle?
What does the gear knob do?
And where is it located?
What year and model is it?
windkind May 22, 2017 01:10 AM
I am talking about the gear shifter on a 2006 tucson.
NovaResource May 22, 2017 10:32 AM
Cheers
I used to own a 2006 Tucson.
You didn't say if this was an automatic or manual but I'm going to assume automatic since a manual trans in the Tucson is a rarity.
It's very easy. At the base of the handle there is a small, oval cover with a tiny notch in the edge. Use a tiny flathead screwdriver to remove the cover. Under the cover is 2 Phillips screws. Remove the screws and the handle pulls up off the shaft.
This should help:
http://www.sound-repair.com/index.ph...-instructions/
windkind May 22, 2017 10:37 AM
This should help:
Hyundai Tucson 05-07 Stereo Removal Instructions / Sound Repair
​​​​​​Thanks, but I have a manual. I can't see any fasteners or clips so I assume it should just twist off.
NovaResource May 24, 2017 08:24 AM
Yes, it just unscrews
