2006 Hyundai Tucson V6 2.7l - Starter
Starter starter is located at the bottom front center under the splash shield easy to remove and easy to replace 1 bolt one nut. The nut is on the top same side as the bolt head. It might have a heat shield on it mine did not. Then you will need a screwdriver you don't need to wiggle it until it falls out then you can unhook your other wires.
