2007 Tucson heater blowing cold air
Our 2007 Tucson Limited (2 litre diesel, RHD UK model) only blows cold air from the heater.
The engine warms up normally, so thermostat is working, coolant level is correct. The pipes into, and out of, the heater matrix both get hot, so I don't think that is clogged. Changing through the various modes blows a strong blast of (cold) air through the correct vents. Is there a flap on the heater matrix that opens and closes to let the hot air into the cabin? If there is, how do I get to it, and how does it work? Is it sensor operated? Would it show a fault code if I got someone to plug it in to a code reader? This happened suddenly, it wasn't a gradual thing, if that helps at all. Many thanks Barry |
Originally Posted by BMC1961
(Post 52978)
The engine warms up normally, so thermostat is working, coolant level is correct. The pipes into, and out of, the heater matrix both get hot, so I don't think that is clogged. The other one should be lots cooler Seems like the heater core is full of deposits blocking the transfer of heat into the cabin. |
Originally Posted by avisitor
(Post 53015)
One hose to heater core should be hot
The other one should be lots cooler Seems like the heater core is full of deposits blocking the transfer of heat into the cabin. That's certainly the way it works on my 50 year old classic car, where everything is easy to get to and there are no sensors or electrics involved. If you want warm air, a fan blows air through the heater matrix, if you want cold air, you open the window or put the roof down. |
If the heater core is clogged then the return hose would be cold
There would be no flow so no heat out But, if the heater core just has deposits blocking the transfer of heat then the return hose would stay hot There would be no transfer of heat to the cabin air A good working heater core will take hot coolant in and return cooler coolant out The heat would transfer to the cabin air and the return hose would be cooler To most people, it would probably just feel hot but it is cooler Try reverse flushing the heater core And there are no sensors in the heater core for the ECU to put up a Diagnostic Trouble Code |
