-   Hyundai Tucson (https://www.hyundaiforum.com/forum/hyundai-tucson-24/)
-   -   2012 Tucson flooded, how to remove carpet? (https://www.hyundaiforum.com/forum/hyundai-tucson-24/2012-tucson-flooded-how-remove-carpet-12930/)
MetalX Aug 10, 2012 08:54 AM
Hi all, I'm trying to remove the carpet. The only part I cant take off is the shifter/arm-rest console. How do I remove the shifter/arm-rest console? Bolts inside the armrest compartment are already removed. Screws on each side already removed.
NovaResource Aug 10, 2012 10:33 AM
https://www.hyundaitechinfo.com/data...slmbd0113d.gif
Console Assembly Replacement
https://www.hyundaitechinfo.com/view...e_icon_eng.gif
• When prying with a flat-up screwdriver, wrap it with protective tape, and apply protective tape around the related parts, to prevent damage.
• Put on gloves to protect your hands.
1. Remove the knob (A).
https://www.hyundaitechinfo.com/data...slmbd0114d.gif
2. Using a screwdriver, remove the floor console tray (A).
https://www.hyundaitechinfo.com/data...slmbd0115d.gif
3. Using a screwdriver, remove the floor console bezel (A).
https://www.hyundaitechinfo.com/data...slmbd0116d.gif
4. Disconnect the connectors (B).
https://www.hyundaitechinfo.com/data...slmbd0117d.gif
5. Using a screwdriver, remove the console upper cover (A).
https://www.hyundaitechinfo.com/data...slmbd0118d.gif
6. Disconnect the connector (B).
https://www.hyundaitechinfo.com/data...slmbd0119d.gif
7. Remove the console tray mat (A).
https://www.hyundaitechinfo.com/data...slmbd0120d.gif
8. Remove the extension side cover (A).
https://www.hyundaitechinfo.com/data...slmbd0121d.gif
9. After loosening the mounting bolts and screws, then remove the floor console assembly (A).
https://www.hyundaitechinfo.com/data...slmbd0122d.gif
MetalX Aug 10, 2012 03:17 PM
This is great, you're a savior. Thank you so much.
