2017 hyundai tucson oil catch can!?
hi, I wanted to see if any is currently using a oil catch can for their hyundai tucson GDI engines (non-turbo). I have a 2017 tucson 2.0l and it being a gdi engine I have considering getting an oil catch can and wanted to see if anyone has already done this with results and we can talk about which one you have set up. thanks!
i have a 2017 tucson se 2.0L with 80,000 miles ,i just installed a catch can a week ago,went with ADD W1 set up.
I cleaned the combustion chamber and valves with CRC value and intake cleaner after noticing a slight rough idle now and then I always changed oil at 3500 miles ,new spark plugs at 50k the pcv value was dirty at 50k so new one too. car uses around 1/2 qt oil between changes tried all different kinds of oil but all around the same,little better with Valvoline syn blend i will post about how much oil is in can |
