Airbag light
Hi all, the airbag light has just come on in my 06 Tucson. My wife has recently been using the car whilst I find her a new one so the drivers seat has been moving position quite regularly. Is there an obvious connector that could have moved and caused it? I’ve had a fiddle under the seat but light is still on. Any help would be much appreciated
It would be good move to have your vehicle checked for any codes. If it shows any , that will provide some direction and save a lot of diagnostic time..
Places like Autozone will usually check for codes at no cost. Post it/ them here .
Wow, located the part and just been to the dealer for a replacement. It’s £227 and no refundable if it isn’t that at fault. Is there any was of testing the sensor to confirm that it is that part that is faulty before I buy a new one??
Usually checks are performed for power and ground (earth). You would require a wiring diagram to determine just where power comes in and where the (earth) connection is located. There could be a rubbed through wire to earth under the seat somewhere . That is what the code might be suggesting.
