Starting Problem
Starting Problem
Hi I have a 2008 Hyundai Tucson. I am having trouble starting it. It seems to have fuel because I hear the pump running but no spark. I checked out you-tube and it was suggested that I change out the CPS (Crankshaft Position Sensor) which I did with no positive results. It has a 2.7lt V6. I checked all the fuses and they seem fine. Just looking to find out if it as a automatic shut down system and where it would be. Help
HI, a mechanic friend brought over his retail 4500.00 scanning tool which told us nothing. After checking a couple of relays he found one not getting any power and turned over fuse box and found two wires corroded off. $4500.00 tool did not help in this case. Thanks anyways.
