-   Hyundai Tucson (https://www.hyundaiforum.com/forum/hyundai-tucson-24/)
-   -   Change washer fluid reservoir (tank) (https://www.hyundaiforum.com/forum/hyundai-tucson-24/change-washer-fluid-reservoir-tank-11798/)
jclhf Nov 18, 2011 10:19 AM
Hi all,
Would someone be so kind and post how to remove/change this fluid tank?
I'm looking for something similar to this:
https://www.hyundaiforum.com/forum/h...ng-rear-10533/
Thanks,
JC
NovaResource Nov 18, 2011 10:35 AM
COMPONENTS
http://www.hmaservice.com/data/Passe...G/etqf880p.gif
REMOVAL:
1.Disconnect the negative(-) battery terminal.
2.Remove the front bumper cover.
http://www.hmaservice.com/viewer/img/note_icon_eng.gif
- When prying with a flat-tip screwdriver,wrap it with protective tape, and apply protective tape around the related parts, to prevent damage.
- Put on gloves to protect your hands.
- Take care not to bend or scratch the cover and other parts.
- Replace any damage clips.
http://www.hmaservice.com/data/Passe...G/esqe400a.gif
http://www.hmaservice.com/data/Passe...G/esqe400b.gif
3.Remove the washer hose and the washer motor connector.
4.Remove the washer reservoir after removing 2 bolts.
http://www.hmaservice.com/data/Passe...G/ktqe220d.gif
5.Installation is the reverse of removal.
http://www.hmaservice.com/data/Passe...G/etqf954a.gif
jclhf Nov 18, 2011 01:40 PM
Thanks a lot for the post.
For the rivets shown, will I have to break them and install new ones in place?
JC
NovaResource Nov 20, 2011 07:37 AM
No. The rivets just hold the bracket to the body. The bumper then attaches to the bracket.
