DIY: maintenance after buying a 2nd hand Hyndai Tucson City 2007
Hi,
I am new member to this forum. Recently bought a 2007 Tucson City SX model. I am now trying to get more involved regarding the maintenance of the car and did my own health check. Things I found out: 1. engine oil - seems fine its between "F and L" 2. engine coolant: - I open the lid and it seems almost empty (i think) and I see a bit of dirt (maybe corrosion) but the reservior is made of plastic (is this normal?). I need to refill the engine coolant as it is advice that it should be between "L and F" From manual: --------------------- Use a high quality ethylene-glycol coolant in a 50/50 mix with water. The engine coolant should be compatible with aluminum engine parts. --------------------- - do I need to buy the collant from Hyundai ? or I can by the collant from any automotive shop? - Does it mean that I need to put in 50% egine collant and 50% water on the collant reservior? 3. Radiator - I notice that that the fluid is not on the radiator neck. - I plan to fill up some water until i reach the radiator neck. Question: Can i used the normal tap water form the faucet? or do I need to buy distilled /demineralize water? Itwas also mention on the manual to put in some engine coolant on the radiator? 4. Washer reservior - I open the lid and i don't see any washer liquid as far as I can see. Should I be able to see the washer fluid when you open the lid? - If I need to refill the windshield washer fluid, can i just use the normal tap water from the faucet? I read the maintenance guide and it mention about washer fluid agent which contains alcohol. do I really need to by the washer fluid or can i just use the normal tap water from faucet? 5. Break fluid - it is between "min and Max" so i think it should be fine 6. Clutch fluid - between "min and max" - so should be fine 7. Battery - no corrosion and looks clean 8. Power steering fluid - between "min and max" so should be fine Thanks for your inputs..... regards, -chino |
| All times are GMT -5. The time now is 04:15 AM. |
