-   Hyundai Tucson (https://www.hyundaiforum.com/forum/hyundai-tucson-24/)
-   -   Heated Seats (https://www.hyundaiforum.com/forum/hyundai-tucson-24/heated-seats-12258/)
dkcn52 Feb 21, 2012 12:31 PM
Heated Seats
I am interested in installing heated seats. I have an 05 Tuscan, what does it take to remove the seats from the suv?
NovaResource Feb 21, 2012 02:00 PM
Tools. Mostly wrenches.
SEAT ASSEMBLY REPLACEMENT
1. Remove the seat assembly mounting cover.
2. After loosening the seat assembly mounting bolt and nut, remove the seat assembly.
https://www.hyundaitechinfo.com/data...G/esqe500b.gif
3. Open the connector box (A).
4. Disconnect the connector (B), and remove the seat assembly.
https://www.hyundaitechinfo.com/data...G/ksqe500k.gif
5.Installation is the reverse of removal.
https://www.hyundaitechinfo.com/view...n_icon_eng.gif
SEAT MOUNTING BOLT INSTALLATION PROCEDURE.
- Set the seat into the most rearward position. Check then each slide is locked, and then tighten the front mounting bolt temporarily.
- Set the seat into the most forward position. Check then each slide locked, and then tighten the rear mounting bolt completely.
- Set the seat into the most rearward position. Check the front mounting bolt completely.
- Check that the seat operates to and fro smoothly and the locking portion locks properly.
BTW, it's Tucson (like the city in Arizona), not Tuscan (like the region in Italy).
