hot air with ac and radiator fan not coming on
Old Jul 1, 2020 | 09:50 AM
twnelsonmemphis's Avatar
Default hot air with ac and radiator fan not coming on
Blowing hot air when ac is on and my radiator fan does not come on. I tried replacing relay and no change. Any ideas?
Old Jul 1, 2020 | 03:10 PM
The items you mentioned are protected by fuses.
Do you have a copy of the owner's manual?
How did you determine which is the proper relay ?
In the manual, in the specifications section it should list the fuses , relays and their location and what they protect. There's good stuff in there.
Old Jul 1, 2020 | 10:01 PM
avisitor's Avatar
When turning on the AC, both the radiator fan and AC fan should turn on.
Is the AC clutch engaging? Is the AC fan turning on?
On some cars, disconnecting the engine coolant temperature sensor will turn on the fans.
Check radiator fan to see if it turns easily.
Check to see if there is power and ground going to the fan
Some cars have a fan controller. Don't know about Tucson??
Check fuses and relays.
Check to make sure temperature selector is turned to cool or cold
Is blend door actuator working to select cold air??
AManiscalco2007
Feb 9, 2025 01:00 AM
Crossev
May 18, 2019 10:12 AM
tracyn8
Aug 15, 2017 10:30 PM
wsteinhauer
Jan 8, 2007 12:14 AM
peter
Jan 26, 2005 09:01 PM
