How to drain AT fluid?
Hi,
Can someone explain how to drain and replace AT fluid? A drawing with the location of the drain plug would be great. Mine is a 2005 Tucson in case there has been any change since. Thanks |
Thanks Nova,
I'm still a bit confused. From the drawing I can't tell if this is a view from the bottom or side. Is that drawing for a V6 2.7 engine? Thanks |
That is the bottom of the trans when viewed from the front (driver side on right, passenger side on left). And the engine doesn't matter as the trans is the same for either the 2.0L Beta 4-cyl or the 2.7L V6 Delta.
