Hyundai tucson 2013 got problem with the stop light not working but the middle light
Old Feb 14, 2022 | 01:39 PM
Kreemalsultan's Avatar
Question Hyundai tucson 2013 got problem with the stop light not working but the middle light
Dear sir
My car is hyundai tucson 2013 got problem with the stop light not working but the middle light on the trunk is working and can't open the trunk ( got one push button switch at the trunk itself only) the switch is working I have tested it with multimeter. The bulb light out side the car direct on the battery is working but when I press the break is not working. I scan it with the bluedriver it's doesn't show any errors. Kindly help me
Old Feb 14, 2022 | 07:02 PM
Suggest you check both rear stop lamp sockets for power 12 volts) when brake is applied
If no power is there then you need to go further back in the wiring to see if the power is available where the wires get connected., Usually a plug is around there.
Eaglevision
Mar 12, 2019 04:55 PM
derawn892
Nov 6, 2011 10:33 PM
mitchlub
Mar 28, 2010 06:38 PM
JTURNER
Jun 11, 2009 10:01 PM
