I need help with Tucson 2005 4wd code P0036 HO2S 12 Heater Control Circuit Fault
Old Jan 9, 2014 | 10:44 PM
eduardmt's Avatar
Default I need help with Tucson 2005 4wd code P0036 HO2S 12 Heater Control Circuit Fault
I have a Hyundai Tucson 2005 4wd with error code p0036 that shows:
P0036 Hyundai - HO2S 12 Heater Control Circuit Fault, Bank1 sensor 2
I need a picture that show where the sensor is located, I like to inspect it or replace it if necessary
Old Jan 10, 2014 | 07:00 AM
What engine? 2.0L 4-cyl or the 2.7L V6? We can't read minds here.
For the 4-cyl, there is only one bank.
For the V6, Bank 1 is the bank of cylinders on the firewall side and Bank 2 is the bank of cylinders on the radiator side.
Sensor 1 is the O2 sensor before the cat and Sensor 2 is the O2 sensor after the cat
So if you have a 4-cyl, it's the O2 sensor after the cat. If you have a V6 it's the sensor after the cat on the firewall side of the engine.
Old Jan 10, 2014 | 03:54 PM
eduardmt's Avatar
V6, 2.7 gls
Old Jan 12, 2014 | 08:01 AM
Then it's the sensor after the cat on the firewall side of the engine.
racing1219
Aug 29, 2014 06:56 AM
Travis_1203
Sep 30, 2011 08:55 PM
sivyer2081
Jun 20, 2009 11:54 PM
princesa70
Aug 27, 2007 01:47 PM
leiladrue
Mar 10, 2007 10:09 PM
