-   Hyundai Tucson (https://www.hyundaiforum.com/forum/hyundai-tucson-24/)
-   -   newbe 05 4x4 v6 Tucson with 200300 miles (https://www.hyundaiforum.com/forum/hyundai-tucson-24/newbe-05-4x4-v6-tucson-200300-miles-9785/)
dr-death Dec 14, 2010 07:27 PM
Hello All
I just got a 2005 Tucson 4x4 v6 with 200300 miles :eek:
.. buts its new to me....
have paper work for New motor @ 182k
Rebuild transmission 186k
now i got it :D
Problems
under acceleration it has a vibration in one of the front wheels/axle
front end make noises like control arms have no bushings
check engine light "ON"
p0700
p0741
p0430
that is all the problems i have come across
are these common problems?
what is the Fix? any help ?
dr-death Dec 16, 2010 08:59 AM
05 Tucson GLS 4x4 with 200300 miles
Hello Again Still looking to Fix these bugs!!
I have started to collect some parts
2 front ball joints
4 control arm bushings
Problems
***could this also be a wheel bearings***
p0700
p0741
p0430
dr-death Dec 17, 2010 08:29 AM
Any ideas?
dr-death Dec 21, 2010 09:42 AM
wow no help......no nothing ....must be i need a CHEVY!!
NovaResource Dec 21, 2010 10:08 AM
1. get the wheels inspected for balance and check teh bearings and axles.
2. Inspect the control arm bushings
3. CEL:
- P0700 = Transmission Control System Malfunction (this code just lights the CEL)
- P0741 = Torque Converter Clutch Stuck Off (replace the solenoid)
- P0430 = Catalyst System Efficiency Below Threshold (Bank 2) (check the O2 sensors and if they are operating properly, inspect the cat)
dr-death Jan 4, 2011 08:48 AM
Thank You Nova
now that ive collected all new front end parts i am now looking for Torque Specs
any help ? locations for documented specs?
ball joint nut
ball joint to spindle
tie rod nut
