Power windows isdue
A while back I noticed that the front passenger window would not operate from the main switch on the driver's side. It did however operate from the front passenger door switch. Today only the front drivers window operates, passenger and tear windows do not move either from that main switch or individual door switched. From what I see in the manual it is the same fuse for all windows so don't think its a fuse. Could a faulty driver's side switch be the problem ? Thanks
I'm having the same issue! With the passenger front door and back right side door ( behind the passenger door)
The front passenger door I can roll down with the passenger button but I cannot roll It up, but I can roll it up with the main switch.
The back passenger door on the same side won't roll up or down with either switch.
I have a 2013 and it only has 55k miles. Hasn't been used that heavy.
Any suggestions would be helpful as I moved to Baja Mexico and most mechanics don't speak any English and my Spanish is very limited. ( taking classes but mechanical issues are hard to learn quickly)
