-   Hyundai Tucson (https://www.hyundaiforum.com/forum/hyundai-tucson-24/)
-   -   Radio install for tucson 2008 (https://www.hyundaiforum.com/forum/hyundai-tucson-24/radio-install-tucson-2008-a-6309/)
Footballfan Apr 30, 2009 10:44 AM
I need to remove the proper panels to get at my radio in my 2008 tucson. Can anyone out there help me? Thanks!
NovaResource Apr 30, 2009 12:30 PM
1. Disconnect the negative(-) battery terminal.
2. Remove the shift lever knob(A).
http://www.hmaservice.com/data/Passe...G/kkqe009a.gif
3. Remove the console cover(B), disconnecting the shift lever connector(A).
http://www.hmaservice.com/data/Passe...G/kkqe008a.gif
4. Remove the upper plate from the transmission shift lever, then remove the 3 screws holding the center facia panel.
Remove the center facia panel(A) and disconnect the wire connectors.
http://www.hmaservice.com/data/Passe...G/ktqe260a.gif
5. Remove the audio unit after removing 4 screws.
http://www.hmaservice.com/data/Passe...G/ktqe260j.gif
6. Installation is the reverse of removal.
