Rear hatch remote lock not working
Tucson 2008 model, Rear hatch/glass lock not locking/unlocking when using remote key fob, having to use manual key to lock the rear hatch, however all other doors lock/unlock using the fob with no problem, appreciate any help
You need to check the actuator and any associated cables for binding
Ok Thanks, I'll have a look at those parts.
It looks like you may need one of the following parts 81290-2E020 (BELL CRANK ASSEMBLY - TAILGATE made by Hyundai. #812902E020), 81230-2E010 (LATCH ASSEMBLY - TAIL GATE made by Hyundai. #812302E010), or 87130-2E000 (LATCH ASSEMBLY - TAIL GATE GLASS made by Hyundai. #871302E000). I would suggest a diagnosis before buying anything. Have a good one!
If it only works with the Door Lock button (On door) I would say, Bad remote. If it doesn't work at all, Most likely the Actuator. Have someone sit in the back and listen for the click of the Actuator.
Thanks guys appreciate your help, sounds like it could be actuator then as both key fobs don't operate it, I'll take a further look at it, cheers
I have a 2012 Accent that has done the same thing from brand new, but I can hear the actuator click when I press the button - just doesn’t actually lock the hatch, so would this be a lock issue you reckon?
Originally Posted by JessRose
(Post 56990)
