Remote will not unlock driver door - no interior lights.
Hello all. I have a 2007 Tucson. I rolled down the drivers door window and heard a big clunk and the window froze. I turned off the car restarted it and then was able to roil up the window. Later I tried to use the key remote to unlock the car but it did not work. The red light on the remote lit like normal but I replaced the battery anyway and the door still did not unlock. I can unlock it with the key. Now none of the interior lights work at all. Not when you open any door or try to turn them on manually. Any ideas? I have not tried to open the window again.
Problem Solved. Clunk sound threw me off. Wires in door were loose and window pulled out wire from harness (clunk and jam) causing FUSE to blow. Word to the wise... next time you have an electrical accessory installed... hover over them to make sure they put the wires where they wont interfere with operation.
