service engine light turns on and off with code P0133 gradually ?
2007 Hyundai Tucson 2.7 SE. my service engine light keeps coming on for two days then turns off. But when i start my car again the next day the light comes back on then turns off again that happens gradually . My guess: O2 censor but im not sure how to get the code because the car feels normal any idea. Many thanks Elkarshofy :confused: |
Could be several things:
OBD-II Trouble Code: P0133 Oxygen Sensor Circuit Slow Response (Bank1, Sensor1) |
Hi Tucsonor
Thanks for replay , I hope if you can tell me where is the Oxygen Sensor Located on my Car? |
There are 4 O2 sensors.
https://www.hyundaitechinfo.com/file...1/0336003A.gif Bank 1 is always the side of the engine with cylinder #1. Bank 2 is always the side of the engine with cylinder #2. Bank 1 is the bank of cylinders on the firewall side. Bank 2 is the bank of cylinders on the radiator side. Sensor 1 is the O2 sensor before the cat. Sensor 2 is the O2 sensor after the cat. So the one you want is the sensor BEFORE the cat on the FIREWALL side of the engine. |
Thank you so much NovaResource
Which o2 sensor. There are 4, and they are all different.
Originally Posted by elkarshofy
(Post 43844)
(Post 43525)
service engine light turns on and off with code P0133 gradually?
Originally Posted by tucsonor
(Post 43531)
(Post 43605)
is it in UPSTREAM RIGHT ?
