stereo removal
how do I remove stereo from 2005 Tuscan?
RE: stereo removal
there is 2 screws on the gear shifter. take those out. then it will just slide off. then pop off that bottom part where the gear shifter goes and the will be a bar there. there is about 8 screws in that plus 3 in the back that you need to gwet. after that is done you can pull the whole dash off then unplug everything and everything else is down hill
