Switching to LED bulbs for 16-18 Tuscon
I just got a 2018 Tucson with the value package. It has the standard halogen lights. I was wondering if anyone has swapped the standard halogen headlight housing for the Limited's LED housing or even if someone has put the Limited's OEM LED blub in the halogen bulb housing if that is possible (I know they are different headlight housings). I'm aware there are tons of aftermarket LED bulbs out there but my biggest concern is if you put them on you have to keep off the factory dust cap which keeps dirt and moisture out. Is this true? Just thought it might be easier to buy the OEM LED bulb so if would keep the dirt and dust out. Any thoughts? or pics of the Limited LED bulbs from inside the engine bay would be appreciated.
