Tucson Alignment & General Problems
Hello all!
I am a Tucson Owner from the Dominican Republic and I would appreciatte dearly any help that I can get withSeveral issues I have encountered, I hope this is not too overwhelming for you so I'll post 2 at a time. I just bought this car 4 Months ago. 1) ALIGNMENT: When I am on the Highway the car pulls slightly to the right. I took it to an alignment shop and they told me it was perfect. I also checked the tire pressure and it's ok. Has anyone else encountered this? 2) CARD HOLDER: There is a small card holder (next to the clock) that has spring action to it. It is very useful for holding ID cards and similar. Well I put too many business cards in it and it does not wotk anymore, I think I broke it. Can I buy a replacement part for it? Do you think I can fix it myself by dismounting the dash board? Any comment that can help me out would be thanked. Thanks and regards to all MM |
RE: Tucson Alignment & General Problems
Hi Macnolos;
Read below for some feedback... ORIGINAL: macnolos Hello all! I am a Tucson Owner from the Dominican Republic and I would appreciatte dearly any help that I can get withSeveral issues I have encountered, I hope this is not too overwhelming for you so I'll post 2 at a time. I just bought this car 4 Months ago. 1) ALIGNMENT: When I am on the Highway the car pulls slightly to the right. I took it to an alignment shop and they told me it was perfect. I also checked the tire pressure and it's ok. Has anyone else encountered this? What I suggest is that you take a drive on a road that you know to be flat, and does not have any groves cut into the road, and see if you experience the same problem. Also, watch your tire wear. Tire wear is a great indication of your vehicle is not aligned properly. 2) CARD HOLDER: There is a small card holder (next to the clock) that has spring action to it. It is very useful for holding ID cards and similar. Well I put too many business cards in it and it does not wotk anymore, I think I broke it. Can I buy a replacement part for it? Do you think I can fix it myself by dismounting the dash board? Any comment that can help me out would be thanked. Thanks and regards to all MM LB www.TucsonDrivers.com |
Remember most roads are crowned for water drainage.As for 4wd are supposed to pull,, well thats a line.If a vehicle is aligned within spec, 4wd or not it should not pull.
ORIGINAL: hyundai tech Remember most roads are crowned for water drainage.As for 4wd are supposed to pull,, well thats a line.If a vehicle is aligned within spec, 4wd or not it should not pull. Herin... you need to get the vehicle onto a well know flat road. One a technician is fairly familiar with, to determin whats truth and what's not. The drifting I mentioned about the 4WD. It's true. Guessing from your forum ID, your a true Tucson Technician? Then its a well known fact that the 4WD inherently will drift some. Both left and right. Not alot mind you. It's suttle, but I noticed it the first week I got mine and inquired with... Let just call him, my Hyundai Technician for the time being. Now if macnolos Tucson is doing more than drifting, then, you've got something more that needs to be looked at. Hyundai tech... Since your hear, and to help our friend out... Why not shed some light on what your thoughts are on what you think the cause of the problem could be? |
ORIGINAL: hyundai tech Remember most roads are crowned for water drainage.As for 4wd are supposed to pull,, well thats a line.If a vehicle is aligned within spec, 4wd or not it should not pull. BTW, Im just assuming the Tucson doesnt have adjustable caster...am I wrong? |
Your correct. The Tucson does not have a caster adjustment.
Hey, Thank you all for your help. I must say that the drifting has gone now that I have used the vehicle more, I guess it might have been the tires, since I have had a couple of flats and rotated them. It might be that or I have just gotten used to it inadvertently. Thanks again for your valuable input.
