Tucson Cargo Screen
Hi all,
New here and just had an easy and probably dumb question. Just got a 2011 Tucson Limited and wanted to know if the cargo screen can easily be removed for when I need to put the seats down? Best I can tell you need to use a screwdriver. I was just wondering if there is a release somewhere that I'm not seeing? Thanks |
The screen should be able to be removed by hand. With the screen fully retracted into the bar that goes across the cargo area, push the bar to one side or the other. It's is spring-loaded on one end so it will compress slightly and then the other end can be removed from the mount. Once bar is removed, it should store in a compartment under the cargo area floor.
