Turbo sucking noise
Turbo sucking noise
Hi Guys just joined after the Mrs bought a 2006 2.0 CRTD GSI.
Its been great so far however its only been used in and around town, but we have just used it for a long motorway journey so its been the first time ive had a chance to open it up.
While driving on the motorway and accelerating there is a really loud sucking / blowing noise ( i cant make up my mind which) but it is definitely like a air intake noise from the turbo. my thoughts are a split hose of pipe somewhere.
After driving it for a while i got used to it and could almost turn the noise on and off depending on the position of the accelerator.
Also im not convinced the power, acceleration or torque is that great.
I've took a look at the intake pipes and i think they are not secured at each end either with clips or zip ties. is this normal?
Having only driving this Tucson i have no other comparison.
Anyone care to comment if this is normal or not and if not am i on the correct path with leaking intake hoses?
Thanks in advance
Thanks in advance
My other car is a turbo also and yes you can here the turbo but not the wind being sucked in to it.
Also as stated in the rest of my post im not convinced the power is as it should be which would related back to not enought boost from turbo.
I have never driven a turbo car thats had this amount of intake noise and ive also never driven any other Hyundai, this is why im asking if its normal to on the Tucson.
Turbo sucking noise
Did you sort this as I've just had my turbo replaced, now there is a lot of air noise and total loss of power ?!
Thanks in advance
Thanks in advance
Hope this helps
thx1971
03-16-2011 12:42 AM
