'07 Veracruz Fuel Tank Air Filter
Any help on replacing the fuel tank air filter for an 07 Veracruz would be appreciated. Location? Must be done at the dealer? Can be done at home? Buy at a national auto parts store? Dealer only part? In advance, thanks for all the help!
Why would you want to replace it on a 2007 vehicle? How many miles are on the car?
The manual states that it should be replaced at 30K miles.
I'm fairly sure it's a dealer only part. Most dealers don't change the fuel tank filter until 100K miles. The filter is on the side of the tank:
http://www.hmaservice.com/data/Passe...senfl7131n.gif Air filter is on the upper left of the pic below: http://www.hmaservice.com/data/Passe...senfl7186d.gif http://www.hmaservice.com/data/Passe...senec7104n.gif http://www.hmaservice.com/data/Passe...senec7107n.gif 1. Disconnect the vacuum hoses (A). 2. Unfasten the two mounting bolts (B), and then remove the fuel tank air filter (C). 3. Install a new fuel tank air filter. |
Thanks so very much for the great info!
