Hyundai Veracruz This crossover combines the functionality of a minivan in a sleek exterior with luxury qualities.
Veracruz transmission control module failure
Old 11-09-2016, 04:23 PM
seanD's Avatar
Default Veracruz transmission control module failure
Hello Veracruz gurus. I bought a 2009 Veracruz in April 2015. In November 2015 the ESC, AWD, and abs lights came on and it seemed like it was stuck in first gear. I was driving 55 mph at the time. Once I got it into a parking lot, I could shift into park. I had to push the shift release button to get it into park. After that it wouldn't start at all. It turned out to be the TCM. That cost me $2000 for parts and labor. It is not covered under the power train warranty because it is mounted to the transmission. At the time of this failure I had the progressive snapshot installed. So, this past August(2016) it failed again. Nine months after new TCM was installed. The part was covered under its own 12 month warranty. I just had to pay labor. Then, October(2016) I was driving, heard a clunk and ESC light came on again. Guess what, yep it failed again. Something is making this part fail and the repair shop hasn't benn able to figure it out. 3 transmission control modules in less than 12 months. The part itself costs $1800. Has anyone out there had or heard of this issue? Any help or advice would be greatly appreciated. 2009 Veracruz Limited AWD 114000 miles.
Old 10-22-2018, 12:51 PM
Ltfarrelly's Avatar
Default Same issue
Did you ever figure it out? My car has the same issue. Got a new tcm one month ago and this happened again today.
same
Old 09-16-2021, 09:43 PM
smcdja's Avatar
Default TCM Issues on 09 Veracruz
I am having the same problem with my 09 Veracruz. Any suggestions?
Old 09-17-2021, 07:23 AM
I wouldn't exactly call this advice, but when we get repeated failures of a particular part it can be caused by , poor quality, incorrect installation,underlying electrical problem(s).
Underlying electrical problems could include stray voltages from somewhere in the system or excessive voltage supplied to the component(s).
This should be verified with a check for a service bulletin pertaining to this particular problem or a good tech with a solid electrical background and equip to isolate the cause.
Old 09-17-2021, 11:32 AM
smcdja's Avatar
It is with the dealer, so I would hope that that they have checked all that u suggested
Old 09-17-2021, 06:02 PM
There is no harm in asking if there was a service bulletin referring to the problem.
If there was , they would probably tell you since you asked.
Judy1252
01-07-2024 07:40 AM
Philly R
07-06-2009 08:05 PM
veracruzfans
03-23-2009 02:00 PM
jeff812
12-18-2008 06:52 AM
acdii
03-23-2008 11:13 PM
Quick Reply: Veracruz transmission control module failure
