battery
bought this veracruiz 0n 10/27/2011 was so happy at that time then thinga started to happen.i looked up all the service records and found this car has a history of battery failures.on the first day it was delieverd to the dealer hard start replace battery 10/12/2009.then on 9/16/2011 hard starting replaced battery.after about three days we had this car it did not start it just clicked.called the dealear oh itsthe battery.waited about 30 min it started right up. took a trip no propleam.then 2 mths later same this started right up moved to the end of drive way .when i got back in it wuold not start.about 30 min later it started. this has happen to us 4 times now took to the dealer yesterday afyer it happened again.if kept it over night said the found no probleam .but that the battery failed a load tes/system tes and draw test.replaced battery now that makes three batterys it less than 2 years.this should not happen somethis is killing these batterys and no one can find the probleam.theres no warrning just happens no hard stard on nothing when it happens it happens.need som advice please. jh89296@aol.com thanks jim:confused::mad:
Battery - word of warning
On my wife's Vericruz (2008) we drained the battery accidently. It worked for a week, but she was starting, going miles to work, then starting to go home. Last week she started, drove around the corner to get gas, stopped, then click, click after filling her tank.
With gas stations in the U.S. having "pump gas only" employees she was stuck at the pump for more than an hour until someone came to jump her. So that day I got a new battery on the way home at Pep Boys, popped it in and the positive terminal would not stay put ! Those clamps are very strange to U.S. owners, never seen them before. I then looked closely and the POSITIVE terminal was larger then the NEGATIVE ! ! Never saw that in any U.S. model. What I ended up doing was putting a piece of metal I cut from roofing flashing half way around the terminal to make up the difference. Works. So check you terminal unless you got the battery from Hyundai. |
