how to remove dor panel for veracruz 2008
Hello, I have a veracruz 2008 and I wanted to open the front door panels, does any one have any picture or manual for it?
Thanks |
https://www.hyundaitechinfo.com/data...senbd8188l.gif
DOOR TRIM REPLACEMENT https://www.hyundaitechinfo.com/view...e_icon_eng.gif• Take care not to scratch the door trim and other parts. • Put on gloves to protect your hands. 1.Remove the quadrant inner cover (A). 2.Disconnect the connector (B). https://www.hyundaitechinfo.com/data...senbd7024d.gif 3.Remove the inside cover (A). https://www.hyundaitechinfo.com/data...senbd7025d.gif 4.Remove the cap (E). 5.Loosen the door trim (D) mounting screws. Release the clips that hold the door trim, then remove the door trim by pulling it upward. Disconnect the power window switch connector (A), power mirror connector (B), and door courtesy lamp connector (C). https://www.hyundaitechinfo.com/data...senbd7026l.gif 6.Remove the inside handle cable assembly (A). https://www.hyundaitechinfo.com/data...senbd7027d.gif 7.Installation is the reverse of removal. https://www.hyundaitechinfo.com/view...e_icon_eng.gif• Make sure of connectors is plugged in properly and each rod is connected securely. • Make sure the door lock and opens properly. |
Thank you, Nova. Much appreciated..
I realize this is an old thread, but it was very helpful. I had to change out the arm rest due to rubbing damage.. and the instructions helped immensely.
1 note, the tweeter panel removes by popping the top out first then lifting the bottom up and out. Also, the Koreans sure like screws!!! I never knew there could be so many screws holding a door panel together, LOL Thanks again Nova for fixing the pics.. they were very helpful. No screws left over, and no scratches on the panel :-). Much Appreciated. |
how to remove front door panel
hi can some one gide me on how to remove the driver door panel,so i ca change the armrest, thanks, for any help.
How to Remove Door panel from 2008 veracruz
Hi I am looking for instructions on how to remove a rear passenger door panel from a 2008 Veracruz so I can either remove or replace the speaker
Thanks |
Hiya and.... Help! :-)
The pics are gone. All I see are question marks (?) inside little boxes. How can I view them? Any help appreciated. |
Hi NovaResource,
I'm unable to see the pics that you posted. Any advice/help? Ken |
Update... DRIVER'S DOOR PANEL IS OFF!
A friendly tech, at my local dealership (Napleton's), helped me out! There was one more screw, located behind the door handle. The "cupped" panel, where the door handle is recessed, just needed to be pried/popped out. Screw was behind there. |
we really need the pics! i removed everything... as far a bolts and screws but that metal panel will not come off. maybe i need to remove the window power motor? it makes sense but just not willing to try it yet. I need to change the actuator but canīt access it yet.
| All times are GMT -5. The time now is 05:40 AM. |
