How to remove the rear trunk door panel?
Hello, I have a veracruz 2011 and I want to install a backup camera and do the wirings myself. But I don't know how to open the trunk door panel, does any one have any picture or manual for it? Thanks.
Tailgate Trim Replacement
https://www.hyundaitechinfo.com/view...e_icon_eng.gif • When prying with a flat-tipped screwdriver, wrap it with protective tape, and apply protective tape around the related parts, to prevent damage. • Put on gloves to protect your hands. 2.After loosening the screws the remove the tailgate inside handle (A). 3.Remove the side tailgate trim (C) and upper trim (B) and side trim (E). 4.Installation is the reverse of removal. |
Thanks for the information
how to remove upper trim(B)
How do I remove the upper trim(b) from Tailgate.
I want to seperate theoutside door handle trim from the panel. A little of rust is developed in the outside between outside door handle trim and door panel. Hyunda declined warranty to repair this rust because it is over 3 years in canada.( year 2008, only 55000 km, 3 year 11 months) Thanks |
You can register on this web site: https://www.hyundaitechinfo.com/ and you'll get access to all technical documents.
| All times are GMT -5. The time now is 01:59 AM. |
