-   Hyundai Veracruz (https://www.hyundaiforum.com/forum/hyundai-veracruz-44/)
-   -   Oil leak onto alternator (https://www.hyundaiforum.com/forum/hyundai-veracruz-44/oil-leak-onto-alternator-18815/)
Painter Nov 23, 2020 08:22 AM
Oil is leaking onto my alternator. Is there a recall for this?
hanky Nov 23, 2020 12:29 PM
Because all vehicles are not the same , it is important to know the year, model , mileage and some of the recent maintenance work done.
If we were able to actually see the engine , it would be a lot easier to offer any suggestions.
It's kinda like going to the doctor and saying I have a pain. Helps to know where, when, what may have brought the pain on etc. Hope you understand, thanks..
Painter Nov 23, 2020 04:17 PM
It's the front valve cover gasket. It's leaking onto the top of the alternator. I guess I will get a new gasket and replace it. Anyone find a good sealant to put on the gasket to help the seal?
I was going to use Permatex, but if someone knows of something better, I am open for suggestions
Sorry, it's a 2012 Veracruz
I called a dealership and they told me that the person I bought this from already had the recall done.
hanky Nov 23, 2020 06:46 PM
Some engines use a gasket and some use only a gasket maker material.
There is a Permatex prodcuct called RTV black. If you need to use any adhesive with a gasket use it sparingly and make sure the surfaces are very clean.and dry.
If your engine is filled with a synthetic motor oil, there is a special Permatex (in a violet tube) product for use with synthetic oil and will hold up well.
Go slow and carefully and all should go well.
Painter Nov 23, 2020 08:29 PM
Thanks.
I Will look for the violet Permatex.
Jennifer Murtaugh Dec 3, 2020 12:07 AM
Yes there was a recall, i had the same issue on my 2011, got it entirely fixed for free and reimbursed for the battery and alternator i bought as well as the towing fee.
hanky Dec 3, 2020 07:48 AM
Thank you for the info and update.
