-   Hyundai Veracruz (https://www.hyundaiforum.com/forum/hyundai-veracruz-44/)
-   -   Valve Cover Gasket Leak on 08 Limited (https://www.hyundaiforum.com/forum/hyundai-veracruz-44/valve-cover-gasket-leak-08-limited-16387/)
luvmycruz Apr 5, 2017 04:04 AM
Has anybody had any dealings with Hyundai when the valve cover gasket leaked oil onto the AC compressor and caused it to fail after the warranty ran out? There was a recall in 2014, gasket was replaced, but it still leaked. Hyundai just replaced the gasket again, but would not replace AC compressor.
Raphael Saibel Jul 4, 2020 06:07 PM
Solution for valve cover leaks
The solution is simple: change the valve cover with a new one, or just pass it on a plain. I've changed the valve cover seal 3 times, 3 alternator rebuilt, until I discovered how to fixed it. Please share this solution in another forums. It's the only way to fix it.
hanky Jul 5, 2020 06:43 AM
There is always a reason for repeat problems . What was the reason the valve cover needed to be replaced here, thanks.?
Raphael Saibel Jul 5, 2020 12:30 PM
Warped, deformed, I don't know the exact technical term to express. I'm brazilian. I passed a planer and it's fine since two years or 50000 km ago.
hanky Jul 7, 2020 06:48 AM
Good tip, thank you .
