Veracruz 115 Volt Power outlet
I have a 2008 Veracruz. I plugged a 120 volt device in to the 115v rear power outlet that looks like a household outlet. Didn't realize my mistake at the time. I blew the 30 amp fuse that's in the engine compartment. I replaced the fuse but it blew out when I attempted to use the outlet again. Is there a second fuse or relay that I have to replace?
The problem is what you are plugging into that outlet. It's too much for it. Replace the fuse again and try plugging something small into that outlet. It should work. If not, you may have damaged the outlet the first time the fuse blew.
I should have made it clear that I used a proper voltage/amp device when it blew the second time. Just returned from camping so I'll get another fuse and try once more.
I have 2008 Veracruz in Canada
My power outlet on the passenger side at the back clearly says 12 volt Is there another at the back for 115/120 volt, or have you made a mistake and have just 12 volts like me? |
The power outlet on my 2010 Veracruz stopped working also. I replaced the fuse and the relay and still nothing. any ideas?
| All times are GMT -5. The time now is 02:08 AM. |
