-   Hyundai Veracruz (https://www.hyundaiforum.com/forum/hyundai-veracruz-44/)
-   -   Veracruz center console removal (https://www.hyundaiforum.com/forum/hyundai-veracruz-44/veracruz-center-console-removal-6293/)
biffstr Apr 27, 2009 09:33 PM
my wife spilled coffee into the cup holders in the center console of her veracruz. She wants me to pull it so she can shampoo the carpet. Any Idea how I will get this done?
NovaResource Apr 28, 2009 08:49 AM
http://www.hmaservice.com/data/Passe...senbd8190n.gif
FLOOR CONSOLE REPLACEMENT
NOTE:
- When prying with a flat-up screwdriver, wrap it with protective tape, and apply protective tape around the related parts, to prevent damage.
- Put on gloves to protect your hands.
1. Remove the knob (A).
http://www.hmaservice.com/data/Passe...senbd7054d.gif
2. Remove the under cover (A).
http://www.hmaservice.com/data/Passe...senbd7055d.gif
3. Disconnect the connector (A).
http://www.hmaservice.com/data/Passe...senbd7056d.gif
4. Disconnect the connector (A).
http://www.hmaservice.com/data/Passe...senbd7057d.gif
5. Remove the mat (B).
6. Using the screwdriver, remove the cool box cover (A).
http://www.hmaservice.com/data/Passe...senbd7059d.gif
7. Remove the console extenser cover.
8. After loosening the console mounting screws, remove the floor console assembly (A).
http://www.hmaservice.com/data/Passe...senbd7060l.gif
9. Installation is the reverse of removal.
NOTE:
- Make sure the connector is plugged in properly.
- Replace any damage clips.
ARMREST REPLACEMENT
1. Remove the storage box (A).
http://www.hmaservice.com/data/Passe...senbd7061d.gif
2. Remove the rear console cover (A).
http://www.hmaservice.com/data/Passe...senbd7062l.gif
3. After loosening the armrest mounting screws, remove the armrest (A).
http://www.hmaservice.com/data/Passe...senbd7063l.gif
4. Installation is the reverse of removal.
CONSOLE EXTENSER COVER
1. Remove the extenser cover (A).
http://www.hmaservice.com/data/Passe...senbd7064d.gif
2. Installation is the reverse of removal.
RussellNCook Dec 22, 2011 01:43 PM
Some coins have fallen under the popup cover so I too need to remove part of the center console. How do I get the knob off in step A?
I've removed the plastic insert on the knob but I didn't see a set screw. Did I completely miss it?
Coachgaines3 Jan 9, 2021 10:41 AM
did you ever figure out how to remove the center console in the Veracruz?
