-   Hyundai Veracruz (https://www.hyundaiforum.com/forum/hyundai-veracruz-44/)
-   -   Veracruz Dash (https://www.hyundaiforum.com/forum/hyundai-veracruz-44/veracruz-dash-6017/)
Stephen Mar 23, 2009 02:08 PM
Veracruz Dash
Does any one know, If I pop the centre Dash to get to the back of the head unit will it pop back on again or is it going to be all broken clips and major hastle?
Thanks,
Stephen.
:confused:
NovaResource Mar 23, 2009 05:56 PM
http://www.hmaservice.com/data/Passe...senbd8204n.gif
CENTER FACIA PANEL REPLACEMENT
NOTE:
- When prying with a flat-up screwdriver, wrap it with protective tape, and apply protective tape around the related parts, to prevent damage.
- Put on gloves to protect your hands.
1. Disconnect the negative (-) battery terminal.
2. Remove the air vent panel(A).
http://www.hmaservice.com/data/Passe...senbd7067d.gif
3. Remove the connectors (Hazard lamp connector, incar temperature sensor connector).
4. Remove the center facia panel (A) after loosening the screws(6EA).
http://www.hmaservice.com/data/Passe...senbd7068l.gif
5. Remove the mounting screws(6EA) then remove the audio unit.
http://www.hmaservice.com/data/Passe...senbe7018d.gif
6. Installation is the reverse of removal.
Stephen Mar 24, 2009 09:37 AM
WOW. Thank you that will be very helpfull.
Stephen
