Veracruz Intermittent Start Problems! Help please!
I have a 2008 Veracruz. Every once in a while, I have to turn the key 20-30 times to get the vehicle to start. I've had the battery, starter, and alternator all checked. The alternator was actually just changed. The intermittent issues started soon after the alternator was changed on the leaky valve replacement recall. When I turn the key, all systems start. The lights come on. Radio comes on. Everything comes on except for the car. Does anyone have any answers to this issue? I see that the Sonata has similar issues too. Thanks for any guidance.
Take a test light and connect one end to the battery negative terminal and the other end to engine block.
Then crank engine. If the test light turns on then you have a bad ground.
If there is no light then test power and ground going to starter.
