02 - rattle & banging in the rear area
Old Dec 23, 2007 | 04:47 PM
MFF's Avatar
MFF
Default 02 - rattle & banging in the rear area
Just turned over 80K- have been happy with this car-
Have this noise coming from the rear- could it be the shocks? have checked them and can't find anything loose?
Old Dec 23, 2007 | 05:14 PM
Doohickie's Avatar
Default RE: 02 - rattle & banging in the rear area
It could be:
1. Bad rear struts.
2. Bad rear strut mounts.
3. Bad sway bar bushings.
A friend of mine bought the extended warranty for his XG and I think he had a problem with the strut mounts and got them replaced under warranty at about the same mileage.
Old Dec 26, 2007 | 03:54 PM
madindian1's Avatar
on top of the rear struts there are insulator bushings, they go bad and that's what you have to replace. the part is cheap.
Old Dec 27, 2007 | 11:11 AM
MFF's Avatar
MFF
There is a 17mm nut on top, once that is removed- is the insulator bushing accessible?
Old Dec 27, 2007 | 02:08 PM
MFF's Avatar
MFF
After bouncing the rear of the vehicle, I knew the shocks were okay.
Jacked up the rear and removed wheels, could notsee that any bushings on any of the linkage were bad.
After replacing the wheel's & lowering the vehicle, placed a mirrow where I could see the top of the shock- the insulation bushing were gone- 1/4" gap. Will order new ones.
Thanks for the advise- will let you know if this solves the problem- 95% sure it will.
Mike
Old Dec 4, 2008 | 10:31 PM
teachdqs's Avatar
I have the same problem on my 2001 XG350 with 90K miles. Appears that I need to replace the rear strut bushings.
Can you please provide instructions on how to DIY them. Do I need special tools?
Thanks for your help.
teachdqs
Jan 2, 2009 02:37 PM
millhouselives
Oct 1, 2008 08:44 AM
bumbleberry
Apr 15, 2008 05:49 PM
berbes
Apr 20, 2007 09:14 PM
emtbch
Jul 2, 2006 07:58 PM
