Cabin fan runs in 3rd&4th speed only-won't shut off
Blower cabin fan will not shut off- operates in 3&4 only- low speeds will not work.
Is there a relay? location? |
RE: Cabin fan runs in 3rd&4th speed only-won't shut off
ORIGINAL: MFF Blower cabin fan will not shut off- operates in 3&4 only- low speeds will not work. Is there a relay? location? |
ORIGINAL: NovaResource ORIGINAL: MFF Blower cabin fan will not shut off- operates in 3&4 only- low speeds will not work. Is there a relay? location? |
Did you ever resolve this issue? I'm having the same exact problem.
Have not -don't how to remove the dash- to get to the switch- if that is the problem?
[/align]MFF |
Thanks for replying. I've gotten some advice suggesting it's the blower motor resistor. You can see the shop manuals if you register at
http://www.hmaservice.com/ It's located behind the glovebox in my Santa Fe. Good luck and keep me posted. I'll reply if I get any more info. |
| All times are GMT -5. The time now is 07:20 AM. |
