External Amp Location/Aftermarket Deck Problem
Old Mar 19, 2008 | 11:49 AM
lancejohnson's Avatar
Default External Amp Location/Aftermarket Deck Problem
I have a 2002 XG350 and I am replacing the factory cd player with an aftermarket pioneer headunit. Problem is when the harnesses are connected either thereis no sound but everything else works on the aftermarket headunit or if i connect the remote from the aftermarket harness to the factory harness the speakers work but at an excessive volume and it overloads the circuit popping the fuse for the passenger side parking lights but the deck will still function after the fuse blows(2 fuses 1 circuit). I was told my xg has a factory amp I need to bypass so any suggestions on where the factory amp is located or bypassing it without running all new wires would be excellent. Also any mods know for the xg's and where to find them too. Thanks
Old Mar 20, 2008 | 10:23 AM
madindian1's Avatar
Default RE: External Amp Location/Aftermarket Deck Problem
can't remember off hand where the amp is located but you can try looking in either sides of the rear quarter panels.
Old Mar 29, 2008 | 01:07 AM
la4xg350L's Avatar
Unless i am completely wrong, I think each speaker has its own amp. I put some subs in my car and in the back I saw that each speaker has a box with wire that was hot when the car was on only going into it. I don't know if that helps you or not, but its something I noticed.
good luck.
Old Jul 13, 2008 | 09:34 PM
Lancer77's Avatar
usually with a factory amp the best way to wire the system without totally hacking up the harnes and having a bunch of splices is to run your own wires.
Old Nov 21, 2008 | 02:11 PM
foofer0013's Avatar
Regarding that external amp. I too tried connecting the remote amp to the wire harness and got excessive volume. I have not tripped or blown any circuits. I think if I can locate the damn thing I could turn down the frequency, which should fix the problem. If that external amp is adjustable this might be an easier solution than by-passing it by running all new wires.
Let me know if you got your system up and running properly. I should indicate that I own an 04' XG350 and installed a JVC-KD360 head unit. Hit me back when you get a chance.
Later,
Dave
gcleeton
Jul 10, 2012 10:48 AM
nicko0409
Jul 10, 2012 10:42 AM
tcromey3
Oct 2, 2011 02:01 PM
surfguy17
Apr 6, 2010 06:57 PM
MSeaman
Oct 4, 2009 07:44 PM
