p1193 code help!!
Old 06-05-2009, 01:07 AM
m5james's Avatar
Banned
No help, really?
  #12
Old 06-07-2009, 12:50 PM
m5james's Avatar
Banned
Ken, is it possible to get some extra assistance? I'm leaving on the 14th back to Boise, so i'd like to be able to have his car running before I leave.
I don't know which part to get, nor do I know which online stores you guys purchase parts from.
  #13
Old 06-08-2009, 11:50 AM
m5james's Avatar
Banned
Bump bump
  #14
Old 06-10-2009, 12:16 AM
m5james's Avatar
Banned
'm honestly suprised that the forum members here aren't willing to help more. I'm having just as much luck here as the dealerships.
If no one is willing to take 5 minutes out of their day, can someone at least give me 5 seconds and give me websites where they've ordered parts from when they had this same problem or others? I hope to god you guys have more options that the stealerships.
  #15
Old 06-10-2009, 10:02 AM
There are plenty of members here WILLING to help. Did it ever occur to you that those WILLING members just might not know the answer?
Sometimes a problem just needs to be fixed by someone that knows what they are doing and has experience with that problem. You call them "stealerships" but that is totally unfair. Most Hyundai dealerships I've used have been very helpful and go out of their way to fix a problem.
I'll give you an example. When I has a TPMS sensor light go on in my Tucson, I took it to the dealership to have it looked at. They found one sensor had stopped sending a signal. They replaced it free under warranty. While that may not be surprising there is one important fact I left out. That is that I had different wheels on my Tucson. I replaced my 16" Tucson wheels with 18" Veracruz wheels. An while they are still Hyundai factory wheel, I removed the sensors from the Tucson wheels and installed them in the Veracruz wheels. That alone could have voided my warranty on the sensors. They called to ask me about it and I told them the truth. They still replaced the faulty sensor for free.
  #16
Old 02-12-2018, 10:31 PM
David Underwood's Avatar
Default Vacuum lines?
Originally Posted by schepebc
Well to make a long story short, I was doing a tune up on my lady friends car and did everything text book and when I started it back up made this horrible banging sound. Took my stethoscope and did a compression check and found out it was coming from cyl. 1. Checked the plug, it was the right one, stuck the bore scope down it to see the piston pitted. End up taking head off to find a small washer was banging around in it. Bent a valve so had the head redone by the machine shop, put it all back together go to start it and it runs rough then dies and once it dies, shoots a P1193 code (limp home) and that’s it. I've been checking vacuum leaks and everything is plugged in. Seeing what is all on that circuit or what it entails to trip it because I haven't run a crossed it before.
Thanks a lot!
Shep
When I changed the vacuum line going to the center position on the throttle body with 3 little things there for vacuum lines there was a tiny brass valve inside the vacuum line.
bwrumfel
07-20-2013 11:17 AM
struckproducts
03-19-2012 06:21 PM
blackbox19
08-06-2010 09:59 PM
mywifescar
07-11-2010 08:51 PM
95accent0321
09-11-2007 11:51 PM
Quick Reply: p1193 code help!!
